New UVEX3 N3-N4-N5
Re: New UVEX3 N3-N4-N5
Postby Ibrahima » Thu Jun 04, 2020 4:04 pm
Super.
Merci beaucoup.
Cdlt,
Ibrahima.
Ibrahima
Calibrex
Postby Tony Rodda » Tue Jun 23, 2020 2:42 pm
Hi Guys,
I've built the Calibrex (to go with my UVEX3) and all is well - except one thing...
I can't get the servo to move.
The servo works for other Sketches. I changed the servo just in case. I've provided separate power to ensure it's not the PCB.
The 78L regulator has a 4.98V output which shows on the servo power pin. Is that high enough? The input is 12.4V.
There is continuity between pin Nano D9 and the servo signal pin.
Still no movement.
I'm using Arduino 1.8.13 (Windows 1.8.39). The Nano is a V3 at328p CH340C (using the old bootloader from the menu).
All the LED's, "Relco", Flat and Ascom driver/app work fine.
Before I change 78L and order different servos, are there any dependencies that you know of for the Nano or servos?
Keep up the excellent work!
Regards
Tony
Tony Rodda
Postby lopez villanueva » Thu Jun 25, 2020 6:09 am
Hello, Tony.
The power supply of the servo used is 5V, we use the 78L05 to have a sufficient intensity because the nano output is insufficient. Also you have 4.98 V is perfect. It is necessary that the ground is well connected also to the servo, finally you have the control which comes from D9 of the nano. You can try your servo on a free table. It should work without any problem. Be careful, you also have 12V servo, we have 5V.
Have a nice day.
Alain
lopez villanueva
Postby lopez villanueva » Thu Jun 25, 2020 6:14 am
The link where you can find the pattern:
http://spectro-uvex.tech/wp-content/upl ... 102907.pdf
Alain
lopez villanueva
Postby Tony Rodda » Fri Jun 26, 2020 1:32 pm
Hi Alain,
Thank you for your response.
I can confirm that the servo I use is a 5V MG90S and that I'm using a 78L05 in the diagram you posted.
I've used a separate, direct, ground but still nothing. The servo just "ticks".
When I provide a separate 5.3V supply the servo works perfectly.
Perhaps the servos I am using are not good. I have ordered the same specification (MG90S) from a different supplier.
Regards
Tony
Tony Rodda
Postby lopez villanueva » Sat Jun 27, 2020 5:03 pm
Hello
Tony to make a test you can put a 7805 regulator (same wiring) which allows to have an output current of 1A instead of 0.1A with a 78L05.
I can only see that, on our side we don't have this problem on our motor servos, maybe you came across a motor servo that consumes more than the average. You keep me informed.
Have a nice day.
Alain
lopez villanueva
Postby Michel Tasse » Thu Dec 10, 2020 4:31 pm
Bonjour Pierre,
Dans ton post du 23 novembre 2019, tu mentionnais la commande de plusieurs types de lampes Tungstène (12V). Pourrais-tu me donner la référence de la lampe Tungstène finalement retenue ? Je suis en train de fabriquer un boitier Calibrex et sauf erreur, je n'ai pas vu cette référence sur le site UVEX-Calibrex.
Merci pour ton aide.
Michel
Dubreuil Pierre wrote:Bonjour Michel
Cette semaine, avec Alain Lopez nous avons monté un mon module CALIBREX.
Pour le guidage une ZWO120MM toute neuve !
Les essais sur table derriere une lunette 600x800 donne un champ bien net !( village situé à plusieurs Km)
la fente n'est pas centrée mais on verra avec le spectro UVEX monté, pour l'instant j'ai juste mis une fente Sheliak sur un boitier vide
Concernant la lampe Tungstène, j'ai passé commande pour plusieurs type de lampes, je les attends pour tester.
C'est de toute façon une tension 12V, mais 10w me semble trop puissant.
A suivre
Aspremont (06) Fr
Michel Tasse
Postby Dubreuil Pierre » Fri Dec 11, 2020 3:58 pm
Bonsoir Michel
Concernant la lampe de calibration tungstène j'ai parcouru ce lien
https://www.conrad.fr/recherche?search= ... pe=regular
J'ai commandé plusieurs types, mais choisi une lampe à visser sur un socle.
Surtout prendre la puissance minimun, sinon saturation et echauffement garantie.
Bonne continuation
Postby Michel Tasse » Fri Dec 11, 2020 5:07 pm
Merci beaucoup Pierre, je vais tenir compte de tes conseils.
Bonne soirée.
Michel
Dubreuil Pierre wrote:Bonsoir Michel
Bonne continuation
Michel Tasse
Postby Michel Tasse » Sat Dec 26, 2020 2:43 pm
j'ai terminé le montage des boitiers UVEX et Calibrex mais je n'ai pas la caméra adéquate pour commencer le réglages. Je recherche donc une Atik 314L+ ou une ASI183MM Pro d'occasion. Pourriez-vous me conseiller des sites où je pourrais trouver cela ?( j'ai commencé à chercher sur Webastro et Astrosurf).
Je vous souhaite de bonnes fêtes de fin d'année et je vous remercie par avance pour votre aide.
Michel TASSE
Michel Tasse
Previous
Return to UVEX Project
Who is online
x
