Hello Robin,
Why you don't trry exposure 1200s or 1800s for have more flux ?
AT 2108hld spectrum - a probable nova in M31
Re: AT 2108hld spectrum - a probable nova in M31
Hello Etienne,
Yes 1200s exposures might have helped a bit with such a weak signal. The total flux stays the same but the total read noise would be a bit less (14e- compared with 20e- assuming 16x 5e- read noise.
I decided to calculate the noise contribution from each source (EDIT Aaargh! why does the forum software remove the spaces in the tableRobin Leadbeater wrote: Yes 1200s exposures might have helped a bit with such a weak signal.
counts/bin e- noise e- %
signal 300 17.3 21
sky 700 26.5 50 (includes M31 background and local sky pollution)
read noise 20 28
thermal 13 3.6 1
total noise (RMS) 37
SNR = 8.1
Taking the same total exposure in one exposure would increase SNR to 9.4
Doubling the total exposure time (to 5hrs 20 min) would increase SNR to 12.2
Rainer Ehlert
Hi Robin,Robin Leadbeater wrote:Hi RainerI use the goto controls (eqascom + Cartes de Ciel) to go to the coordinates published for the discovery. I check that I am in the right place by comparing the star field in the spectrograph guider image with DSS images and sometimes also by checking using astrometry.netRainer Ehlert wrote: Is it visible through the imaging camera or the guide camera ? or do we have to find it using the coordinates and pointing at all the bright dots until we see a similar spectrum like you posted.
I then take a series of 10 second exposures from the guider image and add them to identify the "new star" target. (see attached image)
With a target this faint, I cannot see it in short exposures while guiding so I choose another star in the field bright enough to guide on and measure the offset of that guide star from the target.
I then calculate where I need to place the guide star so that the target will be on the slit and start guiding with the guide star at that position. (It is always a relief when the first spectrum appears 10 minutes later !)
Thank you for the explanation.
saludos Rainer
Actually that calculation is wrong. I only included 1 pixel of read and thermal noise instead of the full height of the binning zone so the contribution of read noise is more like 60%. This means taking only 1 exposure instead of 16 would have improved the SNR per bin significantly from ~5.9 to ~9.3Robin Leadbeater wrote:
Now confirmed as an Fe II nova by Wiliams et al from a spectrum taken using the 2m Liverpool Telescope.
http://www.astronomerstelegram.org/?read=12138
(My spectrum taken a day earlier is also referenced there)
