TCP J18292290-1430460 = Nova Sct 2018
Re: TCP J18292290-1430460, mag 10 in Sct
Paolo Cazzato wrote: I Read Stephane Charbonnel used a newton; does someone tell me more?
Clear nights
Regards
Yes Stephane use a Newton telescope but with an eShel spectrograph, just the injection unit is present on the telescope so that the weight is not very important and mechanical flexion doesn't affect the spectrum (the spectrograph is on a table and very stable)
Take a look of his set up
Post by umberto sollecchia »
Bonjour à tous, posizionati sul profilo della nuova osservazione du 19 -07-2018 calibré en flux absolu avec la photométrie contemporaine de Paolo Berardi.
novasct2018_20180719_887_Flux_Umberto Sollecchia.png (21.89 KiB) Viewed 14158 times
Last edited by umberto sollecchia on Sat Jul 21, 2018 6:46 am, edited 1 time in total.
Vincent Bouttard
Post by Vincent Bouttard »
Hello
My little contribution of the Nova Sct monitoring : 10x300s with an Alpy600 spectrograph on Newtonian 250 mm F/4 telescope. I think that the instrumental response and so the continuum is not really good.
The reference star was HD169033 (B5V) to get a nearly similar airmass at the middle of the Nova exposure time. The nova was taken only between 28 and 23 degrees above the horizon ; I've not chosen Gam Sct (A1IV/V) for this reason. I don't know if I've made the right choice.
Vincent
Re: TCP J18292290-1430460 = Nova Sct 2018
Here is a low altitude LISA spectra of Nova Sct 2018, taken 2 weeks ago, from my 2500 meter elevation/dark-sky site (Mt. Pinos, CA):
Although dim (<14 Vmag) strong OIII lines are present showing nice protoplanetary development of the star's outer shell and hits of older (CIII?)
material "lighting-up."
eShel2-Zwo ASI6200MM Pro
