Pgnuplot.exe not found?
Timo Kantola
Post by Timo Kantola »
Hi!
I installed gnuplot,(+ Script files: std.gnu,std2.gnu and std2y.gnu).
I tried drawing a graph, not working. Gnuplot bin folder not included
pgnuplot.exe. Where to get it?
No pgnuplot.png (33.61 KiB) Viewed 8513 times
Terry Bohlsen
Re: Pgnuplot.exe not found?
Post by Terry Bohlsen »
Pgplot likes to be installed in the root directory ie C:\pgplot
I could not get it to work anywhere else.
Terry
Terry Bohlsen
Armidale NSW
Australia
Timo Kantola
Thanks Terry, it did't help pgnuplot.exe is still missing.
Timo
No pgnuplot.png (85.77 KiB) Viewed 8499 times
Hi Timo,
I cannot help with your problem, but as an alternative have you tried Tim Lester's plotspectra for plotting ?
http://www.spectro-aras.com/forum/viewt ... 596&p=7361
You can find a link to the latest version here
http://www.spectro-aras.com/forum/viewt ... 25&p=10162
Hi Timo,
You have to upload an old version of Gnuplot (V4.4.6 for exemple) but not the last version V5.
It's necessary to use a V4 version of Gnuplot to work well with ISIS
Timo Kantola
Thank you Robin!
Plotspectra seems good especially detection and marking of spectral lines (it would been the next question - how to name the spectral lines) :)
Merci Olivier!
Gnuplot V4.4.4 works well !
NGC 40 central star_20180928_840_ktu Plot.png (7.01 KiB) Viewed 8459 times
ngc40cs_20180928_840_ktu plotspectra.png (44.9 KiB) Viewed 8459 times
Timo Kantola
This is not fun. Yesterday Gnuplot worked ok, now it looks like work well, but result is only @.dat file, not .png.
Gnuplot not working.png (103.36 KiB) Viewed 8421 times
