Experience with UVEX3
Antonino Ventura
Re: Experience with UVEX3
Post by Antonino Ventura »
Given the rather good weather in my part, I have developed two other spectra of the stars HD 91120 and HD 79066. I place the two profiles for sharing.
Greetings Tonino
hd79066_20200308_784_Tonino Ventura.png (46.62 KiB) Viewed 6291 times
hd91120_20200308_855_Tonino Ventura.png (31.65 KiB) Viewed 6291 times
To: Antonino,
Do you have any spectra below 4000A to show? So far your spectra looks great, but it would be nice to see
how far towards the UV you can go with your set-up.......
eShel2-Zwo ASI6200MM Pro
Antonino Ventura
I'm doing other spectra in this wavelength range. I'm not sure that the Relco lamps I use allow me to calibrate even on blue. Soon I will try.
Greetings Tonino
Antonino Ventura
Also from the balcony of the house I observed the star HD76868, placed the spectral profile.
Greetings
Tonino
hd76868_20200319_780_Tonino Ventura.png (37.48 KiB) Viewed 6168 times
Antonino Ventura
In these difficult times, the only entertainment we can afford is observation. The last spectrum that I have elaborated is the star HD89884. It is, as always, a Be star whose obtained profile has an R = 807 and a dispersion of about 4.16 A / pixel. Simbad gives for this star a magnitude V = 7.13. While the spectral class turns out to be a B5III, therefore a giant of class B. It is interesting to note the double absorption on the line of the Habeta that the harvested instrument.
Regards
Tonino
hd89884_20200320_815_Tonino Ventura.png (31.93 KiB) Viewed 6122 times
Great Antonio!
...and take care in these difficult times.
Courage !
Antonino Ventura
Hi everyone. I tried to calculate the limiting magnitude of my instrumentation with UVEX. I have a problem with the version of ISIS V5.9.4 because it does not recognize me some commands of the "command line". How can I solve?
Thank you all
Ventura Antonino
