SN 2020jfo in M61
Frederic Pastor
Re: SN 2020jfo in M61
Post by Frederic Pastor »
I wanted to make a spectrum of SN2020jfo, 3 weeks after its discovery. Here is below my contribution cumulating 4200 sec (only):
Sn2020jfo
Sn2020jfo
SN2020jfo publication ARAS.jpg (83.91 KiB) Viewed 2984 times
Despite noise, it fits in GELATO with the SN2008fz, type IIn:
gelato
gelato
gelatoplot (2).png (66.02 KiB) Viewed 2984 times
Recorded at Mag 14.8 the night of 28th of May, according contributors in Rochester site:
http://www.rochesterastronomy.org/sn2020/sn2020jfo.html
Fred
Peter Velez wrote:There are a couple of spurious spikes though the emission at around 6600 is genuine.
Hi Peter, They wont be from the supernovae though they could be galactic perhaps. I suggest first checking that they are not sky lines than have not been subtracted cleanly by the sky background subtraction though. The line at ~5600 in particular has that characteristic shape for this sort of problem.
The velocity of ejecta can be estimated from the absorption component of the H balmer p cygni lines (either relative the the unshifted emission component or relative to the local rest wavelength.) Note the value depends on the line measured as we see to different depths depending on the line observed and I understand the apparent slowing with time observed is mainly due to us seeing deeper into the increasingly transparent ejecta rather than an actual slowing)
for type II eg
http://www.spectro-aras.com/forum/viewt ... 533#p14070
For type Ia the Si II 6355A absorption line shift from rest can be used eg
http://www.spectro-aras.com/forum/viewt ... =30#p12679
Filippenko's paper is a good overview of supernova spectra
https://ned.ipac.caltech.edu/level5/Mar ... rames.html
but in general the lines are so blended and shifted in supernova spectra that separating and identifying the lines by eye is difficult and these days it is generally it is done by fitting to models
