AZ Cas in the violet
Tonight I am trying to get a better SNR on AZ Cas at wavelegths <4000A. (LHIRES with 600 grating) Everything runs out at the left edge of the field. (camera response, grating efficiency, focus) so it takes about 3-4 hours to get 50 SNR. (This is a single 20min exposure) There is also an internal reflection from somewhere at the right edge but fortunately it is the left half of the spectrum which is important.
Re: AZ Cas in the violet
You do like to test yourself Richard, well done on getting this far. One thought that might help. Given that the LHIRES III just has a doublet it might be worth refocusing it on the slit using a violet light (a violet colour filter would do) but then again it would be off for H alpha etc.
