Hello Robin
Thank you for your intervention
it is not simple spectroscopy!
I will try to improve my treatment
Gérard
C/2018 Y1 et questions?
Re: C/2018 Y1 et questions?
Attends Gérard, maintenant tu es un pro !! En plus tu vas au Pic comme à la maison
T'as raisonetienne bertrand wrote:Attends Gérard, maintenant tu es un pro !! En plus tu vas au Pic comme à la maison
je ne comprenais pas pourquoi ni Isis ni Démétra ne parvenaient à trouver les raies sur mes calibrations
il ne me reste plus qu'à faire des essais en fenêtrant pour voir si les softs retrouvent leurs petits
je vais au Pic comme j'irais à l'école, car j'y profite de la présences des copains bien plus avancés que moi
Hello Gerard,
Have you calculated the pixel size to use ? (This is not the same as the actual pixel size)
"A tip for calculate the scaling factor p (or virtual pixel size). Use the formula:
p = 3123 / dx
where dx is the distance between the H alpha and H beta lines measured in pixels along the horizontal axis in a raw image. Try to find the distance to the nearest pixel (the reading of the mouse pointer is sufficient). In the example, the H alpha line is at x = 882, while the H beta line is at x = 535. So dx = 882-534 = 347, and thus the pixel size to adopt is p = 3123/347 = 9.00 pixels."
From this page
http://www.astrosurf.com/buil/isis/guid ... ration.htm
Sometimes you still need to change the pixel size in very small steps until the RMS error drops when all lines are found.
p = 3123 / dx
From this page
Tu veux vendre ta caméra CCD ? J'en cherche une pour imager mais je peux pas y mettre trop cher...
Thank you very much RobinRobin Leadbeater wrote: Have you calculated the pixel size to use ? (This is not the same as the actual pixel size)
I knew that but .... I forgot it!
by doing that I find 5.224 instead of 5.4 and that changes everything
Isis finds all the Balmer rays
for the lines of the calibration module by cons it is always the same
thanks to you, I'm moving forward!
as you will have guessed, I do not speak English, it's google that translates
non, elle me sert pour d'autres choses que la spectro, en grand champs halpha par ex elle se débrouille bienetienne bertrand wrote:Tu veux vendre ta caméra CCD ? J'en cherche une pour imager mais je peux pas y mettre trop cher...
non, mais je regrette mon antique Atik 16HR qui aurait été parfaite pour la spectro mais qui est en rade sans doute définitivement
C'est presque le même pour moi. Je parle français tres mal, comme un ecolierGerard Arlic wrote: as you will have guessed, I do not speak English, it's google that translates
