CDS data parsing
Discussion et échanges sur l'utilisation de MatLab en spectroscopie
CDS data parsing
Postby Stephane Charbonnel » Mon Sep 05, 2016 1:30 pm
A little code to explore CDS data parsing.
You can play with "regexp" to obtain informations of an object from CDS HTML page. To understand all patterns, you must look at the code of the HTML page.
It is necessary to test the size of some results because all informations are not given for all objects (try "VV_Cep" and "HD256128" ... I don't know why this last star).
Stephane
Code: Select all
Name = 'VV_Cep';  % Name from FITS 1D - ISIS; works also with 'VV Cep' for example.
% URL with questions after ?
URL = sprintf('http://simbad.u-strasbg.fr/simbad/sim-basic?Ident=%s&submit=SIMBAD+search',Name);
Str = urlread(URL);
% coordinates :
Type = 'ICRS';
pattern = sprintf('%s.{1,150}TT.{1,5}(?<RA>\\d{2}\\s\\d{2}\\s\\d{2}\\.\\d*)\\s(?<DEC>[+-]\\d{2}\\s\\d{2}\\s\\d{2}\\.\\d*).*<A HREF',Type);
Coord = regexp(Str,pattern,'names');
% Spectral type :
Type = 'Spectral type:';
pattern = sprintf('%s.{1,150}TT.{1,5}(?<SpectralType>\\S{2,20}\\s\\S).*<SPAN',Type);
SpectralType = regexp(Str,pattern,'names');
%MagV :
Type = 'Fluxes';
pattern = sprintf('%s.{1,1200}TT>.V......(?<MagV>\\d{1,2}\\.\\d{2}).*<SPAN',Type);
MagV = regexp(Str,pattern,'names');
%Vr
Type = 'Radial velocity';
pattern = sprintf('%s.{1,150}km/s..(?<Vr>[+-]\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
Radial_Velocity = regexp(Str,pattern,'names');
% PRINT :
disp(Coord.RA);
disp(Coord.DEC);
disp(MagV.MagV);
if size(SpectralType) > 0
    disp(SpectralType.SpectralType);
end
if size(Radial_Velocity) > 0
    disp(Radial_Velocity.Vr);
end
Stephane Charbonnel
Re: CDS data parsing
Postby Stephane Charbonnel » Mon Sep 05, 2016 4:53 pm
A big new version as a function with help of Olivier Thizy. We have also corrected :
* Coordinates are now formated.
* Correction for reading of spectral type.
* Sign of Magnitude V could be '-' ;-) (only for a little number of stars).
* Possibility of only one digit after comma(for French) or dot.
* CDS is sometimes very slow ... so weboptions.Timeout at 10 (seconds).
* Radial velocity > 0 (as 'Gj436', star with exoplanet). It is not yet good for RV with no digit after dot ... (as 'BF_Cyg').
Regards
Stephane
Code: Select all
function CDSdata = CDS_Infos(Name)
% CDS_Infos.m
% Query CDS (Centre Données Strasbourg) for an object and return several
% information from that query parsing...
% v1.1 / 20160905 (c) Olivier Thizy, Stéphane Charbonnel
% Based on an idea/routine from Eran O. Ofek:
%    URL : http://weizmann.ac.il/home/eofek/matlab/
% Name = 'VV_Cep';  % Name from FITS 1D - ISIS; works also with 'VV Cep' for example.
options = weboptions('Timeout',10);
Str = webread(URL);
% RA/Dec coordinates
Type = 'ICRS';
pattern = sprintf('%s.{1,150}TT.{1,5}(?<RAh>\\d{2})\\s(?<RAm>\\d{2})\\s(?<RAs>\\d{2}\\.\\d*)\\s(?<DECd>[+-]\\d{2})\\s(?<DECm>\\d{2})\\s(?<DECs>\\d{2}\\.\\d*).*<A HREF',Type);
% CDSdata.Coord = Coord;
CDSdata.RA = [Coord.RAh ' ' Coord.RAm ' ' Coord.RAs];
CDSdata.RArad = (str2double(Coord.RAh)+(str2double(Coord.RAm)+str2double(Coord.RAs)/60)/60) * pi()/12;
CDSdata.Dec = [Coord.DECd ' ' Coord.DECm ' ' Coord.DECs];
CDSdata.DecRad = (str2double(Coord.DECd)+(str2double(Coord.DECm)+str2double(Coord.DECs)/60)/60) * pi()/180;
% Spectral type :
pattern = sprintf('%s.{1,150}TT..(?<SpectralType>\\S{1,20}\\s\\S).*<SPAN',Type);
SpecT = regexp(Str,pattern,'names');
if isempty(SpecT)
    CDSdata.SpectralType = ''; % Spectral Type unknwon
else
    CDSdata.SpectralType = SpecT.SpectralType;
end
% V Magnitude
Type = 'Fluxes';
pattern = sprintf('%s.{1,1200}TT>.V......(?<SigneMagV>\\S).*<SPAN',Type);
SigneMag_V = regexp(Str,pattern,'names');
if SigneMag_V.SigneMagV == '-'
    pattern = sprintf('%s.{1,1200}TT>.V......(?<MagV>[+-]\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
else
    pattern = sprintf('%s.{1,1200}TT>.V......(?<MagV>\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
end
CDSdata.MagV = Mag_V.MagV;
% Radial Velocity
pattern = sprintf('%s.{1,150}km/s..(?<SignRV>\\S).*<SPAN',Type);
SignRadial_V = regexp(Str,pattern,'names');
if isempty(SignRadial_V)
    CDSdata.RV = ''; % Spectral Type unknwon
else
    if SignRadial_V.SignRV == '-'    % if RV is < 0
        pattern = sprintf('%s.{1,150}km/s..(?<RV>[+-]\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    else
        pattern = sprintf('%s.{1,150}km/s..(?<RV>\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    end
    CDSdata.RV = Radial_V.RV;
end
disp(CDSdata);
% That's all folks!
Stephane Charbonnel
Postby Olivier Thizy » Mon Sep 05, 2016 9:02 pm
version 1.2 with the following changes:
-high Radial Velocoty in case of Quasars taken into account
-check for some errors (when object is not found or for "sn 2016fnr" which seems unknown to CDS)
Code: Select all
% CDS_Infos.m
% v1.2 / 20160905 (c) Olivier Thizy, Stéphane Charbonnel
Str = webread(URL);
% Check if object is found on CDS
if isempty(strfind(Str,'====Sorry, no entry could be found====')) && isempty(strfind(Str,'***Stopped after 10 entries****'))
    CDSdata.Valid = true;
else
    CDSdata.Valid = false;
    return;
end
Type = 'ICRS';
% Spectral type :
if isempty(SpecT)
else
end
% V Magnitude
Type = 'Fluxes';
else
end
% Radial Velocity
else
        pattern = sprintf('%s.{1,150}km/s..(?<RV>[+-](\\d{1,10})|[(\\d{1,2}\\.\\d{1,2})).*<SPAN',Type);
    else
        pattern = sprintf('%s.{1,150}km/s..(?<RV>(\\d{1,10})|[(\\d{1,2}\\.\\d{1,2})).*<SPAN',Type);
    end
end
% disp(CDSdata);
% That's all folks!
Here is a small code for testing, more cases can be added if needed:
Code: Select all
t=CDS_Infos('VV Cep')
t=CDS_Infos('vega')
t=CDS_Infos('hd256128')
t=CDS_Infos('Sco X-1')
t=CDS_Infos('ls5036')
t=CDS_Infos('V1686 Cyg')
t=CDS_Infos('WR 140')
t=CDS_Infos('sn2016fnr')
t=CDS_Infos('sn 2016fnr')
t=CDS_Infos('PG1718+481')
Postby Olivier Thizy » Tue Sep 06, 2016 1:53 pm
OK, here is v1.4 which seems to work fine now.
-Added MagB & MagR
-RV corrected (we were only taking interger part in previous option... still learning pattern in regexp function!)
Code: Select all
% CDS_Infos.m
% v1.0 / 20160904 - first published
% v1.4 / 20160906 - operational, RV bug corrected.
% Output: CDSdata structur with:
%   Valid: true (1) is object is found; false (0) otherwise
%   RA : Right Ascension in standard text format
%   RARad: RA in radian (double)
%   Dec: Declination in standard text format
%   DecRad: Dec in radian (double)
%   SpectralType: Spectral Type of the object
%   MagB: B magnitude (double)
%   MagV: V magnitude (double)
%   MagR: R magnitude (double)
%   RV: Radial Velocity (double) in km/s
% Tested with MatLab201a
% (c) Olivier Thizy, Stéphane Charbonnel
Str = webread(URL);
else
    return;
end
% Basic Data % DOESN'T WORK YET...!!!
%Type = 'id="basic_data"';
%pattern = sprintf('%s.{1,20}<B>.{1,20}(?<BDStdName>.{1,20}<B>.{1,20}--.{1,20}(?<BDType>.{1,200))\\s{1,10}</FONT',Type);
%BasicData = regexp(Str,pattern,'names');
%CDSdata.CommonName = BasicData.BDStdName;
%CDSdata.Type = BasicData.BDType;
Type = 'ICRS';
CDSdata.RARad = (str2double(Coord.RAh)+(str2double(Coord.RAm)+str2double(Coord.RAs)/60)/60) * pi()/12;
% Spectral type :
if isempty(SpecT)
else
end
% V Magnitude
Type = 'Fluxes';
pattern = sprintf('%s.{1,1200}TT>.B......(?<SigneMagB>\\S).*<SPAN',Type);
SigneMag_B = regexp(Str,pattern,'names');
if isempty(SigneMag_B)
    CDSdata.MagB = 0; % R mag unknwon (should we use -99 ?)
else
    if SigneMag_B.SigneMagB == '-'
        pattern = sprintf('%s.{1,1200}TT>.B......(?<MagB>[+-]\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    else
        pattern = sprintf('%s.{1,1200}TT>.B......(?<MagB>\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    end
    CDSdata.MagB = str2double(Mag_B.MagB);
end
% V Magnitude
Type = 'Fluxes';
if isempty(SigneMag_V)
    CDSdata.MagV = 0; % R mag unknwon (should we use -99 ?)
else
    else
    end
    CDSdata.MagV = str2double(Mag_V.MagV);
end
% R Magnitude
Type = 'Fluxes';
pattern = sprintf('%s.{1,1600}TT>.R......(?<SigneMagR>\\S).*<SPAN',Type);
SigneMag_R = regexp(Str,pattern,'names');
if isempty(SigneMag_R)
    CDSdata.MagR = 0; % R mag unknwon (should we use -99 ?)
else
    if SigneMag_R.SigneMagR == '-'
        pattern = sprintf('%s.{1,1600}TT>.R......(?<MagR>[+-]\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    else
        pattern = sprintf('%s.{1,1600}TT>.R......(?<MagR>\\d{1,2}\\.\\d{1,2}).*<SPAN',Type);
    end
    CDSdata.MagR = str2double(Mag_R.MagR);
end
% Radial Velocity
    CDSdata.RV = 0; % RV unknown (should we use another value?)
else
        pattern = sprintf('%s.{1,150}km/s..(?<RV>[+-](\\d{1,10}\\.\\d{1,10}|\\d{1,10})).*<SPAN',Type);
    else
        pattern = sprintf('%s.{1,150}km/s..(?<RV>(\\d{1,10}\\.\\d{1,10}|\\d{1,10})).*<SPAN',Type);
    end
    CDSdata.RV = str2double(Radial_V.RV);
end
% That's all folks!
And as before a list of target I use for testing:
Code: Select all
t=CDS_Infos('vega')
t=CDS_Infos('SAO104807')
t=CDS_Infos('SAO112958')
Return to MatLab
Who is online
cron
x
