Some Be stars
Some Be stars
Some bright Be stars Alpy 600 spectra taken with a small telescope (a Newton 200 mm f/5). A view of the setup (no need of focal reduced, pure achromatic telescope):
beta Lyr:
zeta Tau:
delta Sco:
and some bright stars...
Vega:
Rigel:
Capella:
Re: Some Be stars
Post by Olivier Thizy »
Very nice setup...
It's not clear to me if the limit we see around 3700A is the actual limit of the spectrograph+camera or if this is actually the Balmer serie barrier which drops around 3646A?
Anyway, newtonians are definitively a great option for spectroscopy!...
http://www.shelyak.com/en/
Re: Some Be stars
Olivier, exact, no so clear. Here a detail of my Alpy600 spectrum compared to CALSPEC (see ISIS data base):
The optical quality of Aply600 is good down to 4700 A. For shorter wavelength some chromatism seem visible (of course, the telescope is perfect).
But on Capella spectrum (a UV rich spectrum) the Alpy600 spectral resolution seem correct down to Balmer limit (3646 A) (the resolution of MILES spectrum is adapted to Alpy600 resolution):
Re: Some Be stars
It looks like the 4700A limit is not an instrumental limit but a typical A-type star Balmer barrier and no more absorption lines below 4700A. On Capella, your spectrum goes down to 4600A!
Well, looks like the Sony chip helps there... and a Newtonian is a great way to go for spectroscopy with an Alpy 600...
Re: Some Be stars
Re: Some Be stars
Olivier,
You mean 3700 A, I think ?
We can use also a CCD camera more sensitive in blue part of the spectrum like this :
http://www.ccd.com/images/alta_f47_sens.gif
Re: Some Be stars
Oops - I meant below 3700A and the Balmer limit is 3647A (or 3.39eV) as well explained in second week of EPFL on-line MOOC training - very interesting by the way.
For those interested, registration should close any time soon now as first week is going toward the end and exercises should be done by march 7th!
See:
https://courses.edx.org/courses/EPFLx/P ... T2015/info
