Eta Orionis period with eShel spectrograph
During last month, I took 12 spectra of Eta Orionis to find one or more periods.
All results in the pdf doc :
http://o.garde.free.fr/astro/spectro/Et ... Period.pdf
And an animation of the 12 spectra correct in phase :
The 2D dynamic spectrum
All comments are welcome.
Just one thing, how to use the periodogram fonction in ISIS ?
Re: Eta Orionis period with eShel spectrograph
Superb work Olivier!
This level of research pushes me to seriously
think about getting the LHIRES III.
Do you use any grating other than the 2400 l/mm
with your LHIRES III?
Los Angeles, CA
Hi James,
For this work, I did it with an eShel spectrograph, but it's also possible with a LHIRES III.
I have two gratings with my LHIRES :
- 2400 l/mm
- 1200 l/mm (very useful when the target is not bright enough with the 2400l/mm)
I have updated my document with additional informations on how to do the process with ISIS and the periodogram function.
Très belle observation et exploitation Olivier !
Post by Ernst Pollmann »
Hi Olivier,
a wonderful demonstration of your observations.
Is this periodicity caused by non-radial pulsations?
Ernst
Merci Christian,
Tout cela a été rendu possible grâce à ton soft ISIS :)
Thank you Ernst,
I don't know about the periodicity, I try to read some publication about this star to understand this complexe of 4 stars system.
Olivier,
would you be so friendly, to inform us here about your findings?
I am very interested!
Ernst
To: Ernst,
Great work! Need to send you more VV Cep data when (and if) I can reduce all my 40+ nights
of spectra observations from Jul-Dec2016.
RE:"....I try to read some publication about this star to understand this complexe of 4 stars system."
See:http://adsabs.harvard.edu/abs/2008AAS...211.5722O
This Eta-Ori system is used to "self calibrate" interferometric observations from the CHARA array.
