PNV J00425895+4126279 in M31
UK observer George Carey has discovered a variable object, a possible Nova in M31 which needs a confirming spectrum. It has brightened and last night was around mag 16 so a challenging but possible target for low resolution spectroscopy.
https://britastro.org/node/11195#comment-3646
http://www.cbat.eps.harvard.edu/unconf/ ... 26279.html
Re: PNV J00425895+4126279 in M31
A spectrum recorded with the FLOYDS spectrograph on Faulkes Telescope North
https://britastro.org/comment/3650#comment-3650 (raw spectrum image)
https://britastro.org/comment/3657#comment-3657 (reduced spectrum, not flux calibrated)
The spectrum is noisy but except for NaD in absorption, appears featureless, including nothing obvious above the noise at H alpha
Any ideas what this is likely to be ?
Now confirmed as a classical Fe nova
http://www.astronomerstelegram.org/?read=10754
