Call for RR Lyr and X Cyg spectra
(En Français juste dessous le texte Anglais)
The campaign of RR Lyr continues and we need your spectra to try to detect short phenomena on this star whose period is 0.566782 days, about 13h36'10 ''.
The acquisition protocol is as follows:
- high-resolution spectrograph like LHIRES III or echelle spectrograph like eShel R> 10000.
- wavelength to observe : H alpha, H Beta, D1, D2, HeI 5876
- Unit time exposure not exceeding 900s (to detect small variations)
- Start spectrum time serie 1h before the maxi spectro and end 1h after the maxi spectro (phi = 0,91) but you can also take more exposures before and after.
The ephemerides of the next maximum are available on the following link:
https://www.pulsating-stars.org/ephemer ... chxPS=ephe
Or here are the maxi of October 2017
[IMG] https://img11.hostingpics.net/pics/1548 ... 102017.jpg [/ IMG]
But it is also desirable to obtain spectra outside the maximun with serial times of 900s all over a night ideally and maybe cover a full period.
Another interesting target to follow: X Cyg (the magnitude ranging between 5.8 and 7.6 during a period of 16.39 days), it is accessible with a LHIRES III and an eShel or Sardine.
It is subject to the manifestation of the Schwarzchild effect and it is thus possible to observe the evolution of the H alpha line during the period (splitting of the lines, emissions in the metal lines, presence of P-Cygni-type profiles inverted non-permanent) around phase 0.458.
One of the aims of the study could be to measure whether the maxima period remains the same ?
The results are to be filed in the database :
https://base.pulsating-stars.org
For more information on the RR Lyr campaign, a discussion list has been created:
https://fr.groups.yahoo.com/neo/groups/ ... Lyrae/info
La campagne de suivie de RR Lyr continue et on a besoin de vos spectres pour essayer de détecter des phénomènes brefs sur cette étoile dont la période est de 0,566782 jours, soit 13h36'10''.
Le protocole d'acquisition est le suivant :
- spectro haute résolution de type LHIRES III ou spectrographe echelle R>10000.
- Longueur d'onde à observer : H alpha, H Beta, HeI 5876, D1, D2
- Temps de pose unitaire n'excédant pas 900s
- faire des spectres en commençant 1h avant le maxi spectro et 1h après le maxi spectro (phi=0,91) voir plus.
Les éphémérides des prochains maximum sont disponibles sur le lien suivant :
Ou encore voir si-dessus les maxi du mois d'octobre 2017
Mais il est également souhaitable de réaliser des spectres en dehors du maxi avec des times séries de 900s sur une nuit entière idéalement et couvrir éventuellement une période entière (selon les sits d'observations)
Une autre cible intéressante à suivre : X Cyg (la magnitude variant entre 5,8 et 7,6 durant une pèriode de 16,39 jours,) elle est accessible avec un LHIRES III et un eShel ou Sardine.
Elle est sujette à la manifestation de l’effet Schwarzchild et l’on peut ainsi observer l’évolution de la raie H alpha au cours de la période (dédoublement des raies, émissions dans les raies métalliques, présence de profils de type P-Cygni inversés non permanents) autour de la phase 0,458.
Un des buts de l’étude pourrait être de mesurer si la pèriode des maxima reste la même ?
Les résultats sont à déposer dans la base de donnée :
Pour plus d'information sur la campagne RR Lyr, une liste de discussion a été créée :
A vos spectros….
Keith Graham
Re: Call for RR Lyr and X Cyg spectra
Post by Keith Graham »
I am interesting in getting involved with the RR Lyr campaign. My problem is I find the links to all be in French. In addition, I see that the data base to which we send our data is not only in French, but I need to somehow subscribe with use name and password. I do not see how to join that group. Is there an English version of this information?
Thanks,
Keith Graham
Hi Keith
To subscribe to the data base, just clic on the link "inscription" juste below the box "Connexion"
Sorry, the text is only in french but here's a translation of all the box or field
Identifiant : your pseudo or name
Confirmer identifiant : just re write the same field as identifiant
Nom : your name
prénom, your given name
email : your email
confirmer e-mail : juste re write your e-mail
telephone : your phone number
And press "Envoyer" (SEND)
on the list, you can speak english, no problem....
And for the mailing list, you can send a message here :
groupe_rr_lyrae-subscribe@yahoogroupes.fr
