Hi
I read that you can remove a section of the curve plotted with ISIS (eg a hot pixel or suchlike) by double clicking either side of the unwanted peak but I`ve tried this and it doesn`t seem to work or is there another way please?
thanks
Steve
Editing curve in ISIS!
Re: Editing curve in ISIS!
Hi Steve,
You can do this using the "Continuum" function. (This trick also works in VSpec)
Display the profile, click "continuum" then double click either side of the unwanted feature and a new line is generated with the selected region deleted. If you then just click ok (without any smoothing ie the slider set to zero, or dividing), the result is the original profile with just the selected region removed.
You can also edit individual bin values manually using the "Edit" function
Great ! thanks for that Robin
Steve
Steve
