A new version of PlotSpectra is available.  There have been several small interface bug fixes and a couple of added features (see the revision motes).
There has been an important change regarding log plots.  Prior to this revision data points with values <=0 were always stripped out when loading spectral files.  This enabled log plots but it can affect the  accuracy of measured line parameters where the spectrum is very noisy and the continuum is near zero and contains negative values.  Log plots are now disabled by default and no data points are removed.  If log plots are enabled in settings then zero and negative values will be stripped out and an alert will indicate the number removed as spectra are loaded.
Download link:  https://1drv.ms/f/s!AvXqhKI5kEGRjEhdaQ6jaj8AHx_L
						New version 1-6-0
				Tim Lester
Return to “Software PlotSpectra”
				Jump to
	- Forum presentation
 - ↳ Petites Annonces
 - Current Campaigns
 - ↳ AZ Cas
 - ↳ RR Lyrae
 - ↳ Be Stars survey
 - ↳ P Cygni
 - ↳ VV Cep
 - ↳ Archives
 - ↳ SN 2011fe campaign
 - ↳ Epsilon Aurigae
 - ↳ Novae
 - ↳ T Tauri Stars
 - ↳ Planetary Nebulae
 - ↳ Be Search
 - ↳ CH Cygni
 - ↳ Novae
 - ↳ Symbiotic Stars
 - ↳ Supernovae
 - ↳ Cataclysmic Stars
 - ↳ Be Stars
 - ↳ Comets
 - ↳ Resources
 - ↳ Miscellanous
 - Spectroscopes and Softwares
 - ↳ MatLab
 - ↳ Python
 - ↳ UVEX Project
 - ↳ Sol'Ex/Star'Ex
 - ↳ Software Demetra
 - ↳ Software ISIS
 - ↳ Software VisualSpec
 - ↳ Software SpcAudace
 - ↳ Software PlotSpectra
 - ↳ asdb ARAS DataBase
 - ↳ Android applis
 - Beginners corner
 - Introduction / Présentation
 - ↳ OHP 2014
 - ↳ OHP 2013
 - ↳ OHP 2012
