eShel calibration set-up
Re: eShel calibration set-up
Its almost 9 months latter and I've made much progress on getting my eShel functional.
The problem noted in the beginning:"...I should proceed further seeing that the right-side of the frame has such badly trailed Th-Ar light on these orders."
I determined that the eshel's fiber optic collimator on the unit itself was "lose" so I tightened its 4-bolts and all the system's small hexbolts around the spectroscope and my ThAr order lines got much better; the ThAr light on the right hand side were still worse than the left-hand side.
As Joan mentioned in another post, my Vega specto in LA was 240 sec, much too long! This was due to the fact that my fiber light output in the FIGU wasn't aligned with the light cone. I aligned this "fiber-shadow" with the light cone and got a usable Vega spectrum down to 2-sec with the CDK17!
After much adjustment, I got (more of less) the 3 ThAr spots to align as seen in check3 below:
I was able to get orders from 28-58 without any ThAr\zone errors. I took the following spectra of the image response star alpha Del and variable stars R Aqr and WR140 with the CDK17:
These spectra seem radiometrically correct, with typical errors of 0.1-0.3A around Ha and 0.6-1.4A around Hb and bluewards.
The resolution btw orders 28-58 vary btw R 9.5k-10.5k. My usable spectro range seems to be 3850-7995A. While the check3 isn't as good as what I achieved in LA, I think I can proceed with science on this.
Before I place the eShel2 into the "wine-cooler" and arrange the fiber optic agitators, I will do a more exhaustive test on the camera and (x-y)shifts to see if I can get better check3 results, but looks like there is "light at the end of this tunnel."
Post by Joan Guarro Flo »
Hi James,
Something hasn't worked, but your writing doesn't show the images, please could you try to mend it.
Many thanks, Joan.
To: Joan,
See end of posts on previous page, esp Robin's:
"...I have seen this kind of problem before. I think it is a browser security setting that prevents displaying images hosted elsewhere on a non secure (ie not https) site. For example this is the address of one of the images
http://astroimage.info/files/Vega_thor_bin-2.jpg
Can you see the image if you click on this? If so try right clicking where the blank space where the image is and go to the image address direct
http://www.threehillsobservatory.co.uk"
Unfortunately, I have no where else to post these but my webhost service provider, so these are not "https:" but "http:" Here are direct links(your security settings may still prevent display, however):
http://astroimage.info/files/3-alignmentPTS21Aug25A.jpg
http://astroimage.info/files/alphadelph ... Foster.png
http://astroimage.info/files/raqr_20250 ... Foster.png
http://astroimage.info/files/wr140_2025 ... Foster.png
Hello James,
Without any doubt, that is a great step, so you can observe a lot of targets with very high resolution now.
In this way, I would say to you some little suggestions about your eShel; if I were you, I would try to improve the three points centered as your Check2 image shows. You can gain more precision if they were well centered.
Also, you can notice that in the violet region of your R Aqr graphics, the signal is mixed with noise until more than 4500 Angs, - please, see François' observations of this star -, mend it only requires more integration time, fortunately, the ASI2600MM permits 1800 sec. exposures. Noise + Resolution = Noise.
One thing that strikes me is that your echelle can arrive at the 9000 Angstroms, sometimes it is very useful, as you can see in my X Per observation. The question is, could you defocus a bit the central orders in the aim of gaining range on the infrared region? Minimum until Calcium Triplet; of course, you lose a bit of R, but you could gain in detection range...
I hope that you enjoy this extraordinary device.
Cheers, Joan.
To: Joan
Thanks for your useful feedback all these years! Yes, I'm not at "prime" exposure due to keeping the eshel out of the
"wine-cooler." The coolest I can go is -5 on the ASI2600mm with a fan running close by, because my garage is almost 27C now.
I do not want to place the eshel in the cooler until its fully optimized, but I though I'd share my preliminary results.
I manually construct def_order.lst and def_ypos.lst files everytime I change rot/shift on the colliminator.
I agree, if I get check3 perfectly aligned, I'll get more resolution and better radiometic accuracy from short end to long end of my spectrum. In my old 2022 LA set-up (with almost perfect check3) my resolution was 9.9K to 12k so I've definitely try more 135mm canon lens collminator shifts/rotations to get there. I'm pretty sure I can get to order 60, but anything above order 28 is very hard because almost no Th-Ar points show.
I've gotten by check3 as perfectly aligned as possible; see:
RE:"One thing that strikes me is that your echelle can arrive at the 9000 Angstroms, sometimes it is very useful, as you can see in my X Per observation. The question is, could you defocus a bit the central orders in the aim of gaining range on the infrared region?"
I don't think I can go beyond 8000A. I have constructed the x1,x2,y up to order 26, but I cant seem to get successful zonal checks to this end; lowest into IR is Order 28. Almost all ThAr lines are guess's from order 27-26 and I can't see any ThAr above these....I don't think the visibility will improve unless I drastically defocus everything else and going below 5k resolution......guess I'll keep my LISA-IR handy for 6200-10000A observations!
Joan RE: "...that strikes me is that your echelle can arrive at the 9000 Angstroms"
I've been able to get to order 27 or a little below 8500A, but while my individual orders are radiometric, my merged spectrum (which Francois prefers) are not; i.e. telluric lines around Ha in the merged spectrum (3800-8500A) are off +/- 0.3A or more.
After some more projects are completed with the eshel working at 3800-8000A, I'll reconstitute my def_orders for 27 & 26 and re-focus as suggested to get to 9000A. Fingers crossed!
Hi James,
Really, +/- 0.3A is a bit out of the tolerance...
I hope that you can make things the right way, luck can help you, but it's better not to tempt it.
Joan.
