SU Lyn Call for observations by Katarzyna Drozd
HughAllen
Re: SU Lyn Call for observations by Katarzyna Drozd
Post by HughAllen »
Robin Leadbeater wrote:Hi James,
SIMBAD is not a very reliable guide to spectral type. A better source is Brian Skiff's huge database of references
http://vizier.cfa.harvard.edu/viz-bin/V ... ource=B/mk
There you will see the M2 reference from 1956 and a more up to date reference M6III
Where does this dialogue box come from? I am not sure I understand the connection between spectral type and BeSS and how it might be used
Thanks Robin for the interesting link. Is there also an option to search for reddening factor for any particular star?
Hugh
Hugh Allen
Alpy 600 user
To: Robin,
RE:"Where does this dialogue box come from? I am not sure I understand the connection between spectral type and BeSS and how it might be used"
This is from BaSS V1.96. Its the tool box used to format spectra data for BeSS/BAA database submission. I'm too lazy to individually correct the .FITS header, so I use
BaSS and it auto formats my spectra for me.....will transfer over to Isis for this function as well.
Still trying to get my non H-Alpha spectra processed by Isis, but is more difficult to processing these than the LISA spectra.
In the last observation (April 8), the profile shows an increase of the h-Alpha emission component:
Francisco Campos
Post by Francisco Campos »
Hi, everybody,
a fresh spectrum of SU Lyn from the last night. I'm doing also some BVR photometry with a cadence of 3-4 nights (one point per night for SU Lyn but also for AG Dra) but I don't know where to send the results. Maybe to the AAVSO database?
Greetings
Fran
Hi Fran,
Very interesting spectrum. The range will be perfect for AG Dra and the Raman bands
Yes, I think the best is to send the photometry to AAVSO database
Which star have you used for comparison
Al the best,
Hi, Paolo,
Interesting. A suivre.
Francisco Campos
Francois Teyssier wrote: Yes, I think the best is to send the photometry to AAVSO database
Hi, François,
I use HD 46608 (000-BBL-578) to do photometry (B:7.461; V:7.391 Rc:7.295). It's a good comparison star but you need a wide field scope to observe both stars. I use a 66/400 mm ED and a ST-8XME with the mandatory BVR Johnson-Cousins filters. At this precise moment I'm doing time-series photometry only in the B band, instead of a single-night point, in order to detect flickering or some kind of fast variations.
For spectroscopy I use 11 Lyn (HIP 31665 = HD 46590; A2 V according to Hipparcos catalogue). It's very near of SU Lyn, so I believe it's a good comparison star.
Greetings
Fran
I'm getting my last shots in for SU Lyn.
Now that I'm getting more confident with Isis, I shot a 93 minute (9x600sec + 180sec) 2x2 binned spectra of this fascinating object last night.
Here is the result (spectra lines tentative!):
I got my spectra class for this star from the article: "SU Lyncis, a hard X-ray bright M giant: Clues point to a
large hidden population of symbiotic stars," by K. Mukai and associates; see:
https://arxiv.org/pdf/1604.08483.pdf
Note that I added dA to the computed MKK spectral standard type of M5.8III, since an orbiting white dwarf close to 1-solar mass is the probable
source of hard x-rays for this system. A low gaussian filter was applied to make the spectra a little less "noisy looking."
An update of SU Lyn observations at R > 5000
SU Lyn.png (86.35 KiB) Viewed 11144 times
The red spectrum is the standart M5.5 III VY Leo, for comparison
A very nice coverage near the minimum of emission
See EG And in http://www.astronomie-amateur.fr/Docume ... CE2016.pdf
A 2 or 3 years monitoring will alow to determine the orbital elements
I suggest using the heliocentric velocity tool during the treatment.
Nice SU Lyn results François!
I'm a later comer to this campaign.....going to try AG Dra in Ha tonight as well.
Tomorrow I'll switch back to LISA spectroscopy.
