bug in Vspec saving some fits files
I have found a strange bug in Vspec tonight. If you try loading the attached fits file and then save it, the saved spectrum is shifted about 3A. (It drove me mad tonight trying to work out what was happening. It does not do it with all fits files and ISIS works correctly)
s2008_04_26_19_51_35.zip
example fits file which is not saved correctly by Vspec
(6.5 KiB) Downloaded 499 times
Valerie Desnoux
Re: bug in Vspec saving some fits files
Post by Valerie Desnoux »
Hi Robin
(my password is now restored)
I do confirm this is not working properly. If I save it as spc, it works fine. I see some blank lines in the fits header, I need to take some time to digg into this.
V.-
Valerie Desnoux
I found the bug. It is not the blank lines, but a bad management of a CRPIX1 value which is negative in this file. I will post an updated version soon.
Thanks for your patience and for finding this tricky one.
V.-
Valerie Desnoux
I posted a V4.0.2 on the web - Hope this bug is fixed now. I also solved the Spectrum directory setting.
V.-
