Tartou 2016 VV Cep au Lhires 2400
VV Cep 2017-2019 Campaign
JJ Broussat
Post by JJ Broussat »
Voici un spectre de VV Cep fait cette nuit
Les remarques sont les bienvenues.
Cordialement
Jean-Jacques
Re: Tartou 2016 VV Cep au Lhires 2400
Post by Ernst Pollmann »
Jean-Jacques,
when do you upload this spectrum at the ARAS database?
I am interested in it!
Ernst
JJ Broussat
Hello Ernst,
Here is the file
Best regards
Jean-Jacques
_vv_cep_20160927_998_JJ Broussat.zip
(10.19 KiB) Downloaded 817 times
See revised post below of 01-Oct-2016
observations of VV Cep in CaK, HB, and HA regions.
Los Angeles, CA
Post by Olivier Thizy »
James,
would you mind emailing (thizy@free.fr) me your spectra in FITS/BeSS file format so I can add it on ARAS database?
dB: http://www.astrosurf.com/aras/Aras_Data ... /VVCep.htm
Jean-Jacque,
here comes the Halpha EW and Halpha V/R evaluation.
Ernst
JJ Broussat
Ernst,
Thanks
Jean-Jacques
Here is my spectra for VV Cep taken from Mt. Pinos, California (2500 meters elevation) on
01 October 2016, y-scale normalized to 1:
Center near CaK (7x420seconds summed):
Center near H-Beta line (7x300 seconds summed):
Center near H-Alpha line(7x180 seconds summed):
Spectra were dark/bias calibrated. These exposures were summed in MaximDL, hot-pixel eliminated,
and had a manually generated flat field applied.
These spectrum were further processed in Bass project software 1.94 by being rotated & slant corrected,
above, below subtracted and active (continuum) selected, calibrated with a Ne-Ar reference image taken
right before and after exposure, and instrument response corrected using Vega on the same night.
I normalized the y-axis to a value near 1. Interestingly, this makes my H-Alpha scaled peak of
5 match Tartou/JJ Broussa original post almost perfectly!
Shot with a 33 Cm. aperture classical cassegrain telescope using an Atik 460ex CCD and
a L-200 spectroscope with a 1800 l/mm grating from 2500 meters elevation.
I have another VV Cep batch to process for 02-Oct-2016.
Los Angeles, CA
