bug in Vspec slant tilt
Hi Valerie,
I have just tried the new slant/tilt measurement and correction feature in Vspec but the correction seems to be working in the wrong direction (The slant/tilt is larger after the correction) I have attached the fits files I used to test it
vspec_slant_tilt.zip
fits files for slant tilt test
(2.55 MiB) Downloaded 503 times
Valerie Desnoux
Re: bug in Vspec slant tilt
Post by Valerie Desnoux »
Hi Robin
Thanks for pointing to the issue. I'm going to publish a fix.
Sending the data was key, and easy to fix. It is always a pb when tests are done with always the same spectrograph, you have alwyas same slant or tilt direction to fix...
Valerie
Valerie Desnoux
V405 is supposed to fix the issue... hope my brain is still clear in this christmas time...
V.-
Valerie Desnoux
Brain was not...I had to publish 406 - due to an improvement in the interface, the edition within the assistant of the files List_instru and List_obs was not possible (impossible to find the file was always displaeyd).
Shall be fixed by now.
Valerie
