New black hole binary in outburst (Mag 12.5 in Oph)
MAXI J1820+070 is a new X-ray transient discovered on 2018 March 11 12:50
UT by MAXI (ATel #11399)
It has been associated with a bright optical transient
ASASSN-18ey (ATel #11400) in Ophiucus.
AD (2000) : 18 20 21.95
DE (2000) : +07 11 07.3
The observations show rapid brightening, fast optical variability.
Current magnitude (V) = 12.5
The observations are consistent with a black hole X-ray binary in the hard state
Optical spectra show
strong, broad H-alpha emission
and weaker emission from He I 5875 and the Bowen blend.
The H-alpha has a FWHM of about 1150 km/s. It is asymmetric but not clearly double-peaked
This FWHM is relatively low for a black hole X-ray transient,
suggesting either that the system has a long period associated with an evolved donor or that it is relatively face-on.
here are no obvious absorption features in the spectrum, indicating that continuum is dominated by the accretion disk.
(ATel #11424)
presence of a broad, asymmetric H-alpha emission line
Also detected broad H-beta, H-gamma, and H-delta absorption with emission lines in the center,
characteristic of an accretion disk in outburst.
He II 4686 (with EW = -1.7 Ang) is seen on top of the continuum
(ATel #11425)
Spectroscopy of MAXI J1820+070 is strongly encouraged.
An ideal target in the morning sky for Alpy, LISA and other low resolution spectroscopes
Observations will help to understand the intriguing nature of this source
Spectra will be added to ARAS Eruptive stars database
Send spectra to francoismathieu.teyssier at bbox.fr for inclusion in the database
Use MAXI J1820+70 in the fit header
(ATel #11424)
(ATel #11425)
Forrest Sims
Re: New black hole binary in outburst (Mag 12.5 in Oph)
Greetings!
Spectrum data from last night for MAXI J1820+70 also now apparently known as ASASSN-18ey.
This was tricky catching it after the clouds cleared away and before dawn. This target stood out quite brightly in the place predicted by the AAVSO Chart. I was able to get 6 usable 300sec exposures of the Target before the sky background became too strong. I took 7 30 second images of the A0III Reference star HD181470 for creating the Response curve correction. This target would certainly have benefited from longer exposures if time had allowed.
Thanks
Woody
Thanks
Woody
That's excellent, Woody
Typical spectrum of a dwarf nova in outburst
It could be a polar, according to Steve
A professional spectrum has just been posted on TNS by the ePESSTO team
https://wis-tns.weizmann.ac.il/object/2018amn
Forrest Sims
Here is my data from this morning on ASASSN-18ey = MAXI J1820+070. According to the AAVSO Alert notice 630 there is a "blitz" campaign for two nights (thru 13 April) on this object. They want high cadence photometry. But maybe some 600sec images of the spectrum would be of interest.
Cheers!
Woody
Cheers!
Woody
- asassn-18ey_20180412_438_Forrest Sims anotated.png (36.6 KiB) Viewed 16593 times
Good job Forrest !!
I can't was observed more on last days Nova CMa 2018, because it's cloudy and raining. Here the weather don't will better until next Sunday night.
Regards, Joan.
Regards, Joan.
Hi Woody,
You have a nice and valuable serie!
Let me extend it with a fresh result of today's morning: Conditions were good (target high enough), more of us should be able to follow.
Seeing observers activity on this object again, revisited it the last Sunday morning: The HeI lines have separated clearly.
Exposures info:
2018.04.14 (JD=2458222.5982): 9 x 600 sec
2018.05.05 (JD=2458244.4973): 5 x 1200 sec
2018.06.24 (JD=2458293.5516): 3 x 1200 sec (of 10 min clouds)
Exposures info:
+ Forgot to add:
http://www.astronomerstelegram.org/?read=11756
=> https://cbastro.org/the-astronomers-telegram/2018-june/
=> [...] "The phase stability of the 0.703 d wave makes it a good candidate for the orbital period of the underlying compact binary, although other interpretations (superhump? precession?) are possible. Spectroscopic observation could test this hypothesis, and ascertain the dominant light source in the binary."
Of course, my summer time window + poor horizon access not enough to check this 0.703d. (I am suspecting the large continuum changes doing that.)
Perhaps someone else (or more of us - multiple nights) could do it.
Here is my best spectra of ASASSN-18ey taken from Mt. Pinos, CA last week with a LISA spectroscope on a 33cm aperture classical cassegrain reflector (1-Hr exposure):
The O1 line at 5577A is terlluric. Only very noticeable lines are H-Alpha, H-Beta, & the He II(4685.7A).
