Version 6.0.3 reports lower resolutions for same Alpy data
John Coffin
Post by John Coffin »
Hi, I upgraded my ISIS from version 6.0 to 6.0.3 today.
I was surprised to find that my Alpy spectrum was reported as having a resolution of 455. I reinstalled version 6.0 and processed the same data and the resolution was 527.
Then I went back and reprocessed some more data and found a similar discrepancy between the two versions.
Does anyone know why this should be?
Thanks, John
Re: Version 6.0.3 reports lower resolutions for same Alpy da
I can confirm this.
I see a difference between 6.0.3 and 5.9.3 (my standard as I prefer the black body correction to the response) 5.9.3 gave R=537 and 6.0.3 gave 522 using the same data and the same xml file so the settings should have been identical
Comparing the log files I see there is a difference in the X1, X2 limits. I do not know what these are or how they are used but perhaps they have something to do with it?
John Coffin
Thanks Robin, I’ve emailed me to see if you can send me a copy of v 5.9.3
John
Hi John,
You can download previous versions of ISIS from Christian's website here
http://www.astrosurf.com/buil/isis/download/
