SN 2021aefx in NGC1566 (Dorado)
https://www.wis-tns.org/object/2021aefx
A supernova in a nearby galaxy for southerly observers to keep an eye on. Caught early so currently quite faint. The sub type is unclear from the initial spectrum but in the absence of IS extinction a type Ia could potentially reach as bright as mag 11 if the distance (10 Mpc but with high uncertainty) in NED is correct.
EDIT: a good target for 2SPOT perhaps ?
2SPOT
Re: SN 2021aefx in NGC1566 (Dorado)
Post by 2SPOT »
Yes Robin, we did it this morning : RC 12 inch and Alpy 600 from Deep Sky Chile
Here's the Sn in NGC 1566
And the spectrum
Nice catch! So it is confirmed as a Ia, Do you have an estimate of the brightness? The spectrum does not look obviously reddened so it could be heading for being the brightest SN for some time
2SPOT
Post by 2SPOT »
I think the Sn is around mag. V=15,5
Here's a quick comparison with others stars in the field
Hamish Barker
Post by Hamish Barker »
great work, such a nice composition too with the big spiral galaxy!
Still rising rapidly in the ASAS-SN forced photometry data (Latest Mag 13.6 but that is likely an over estimate given contamination from the galaxy)
https://asas-sn.osu.edu/sky-patrol/coor ... d7d7314ceb
Terry Bohlsen
Post by Terry Bohlsen »
Hi All
I took a spectrum of this SN last night with my LISA. R=~1600
Terry
Terry Bohlsen
Armidale NSW
Australia
There is an image using SLOOH from last night on the BAA forum where it looks to be ~mag 13.5
https://britastro.org/comment/11199#comment-11199
and running the 2SPOT spectrum through SNID, it estimates it was ~10-12 days away from maximum then so maximum around 25th. Plenty of time for it to get a lot brighter yet.
It has now reached maximum at mag 12 (g)
https://asas-sn.osu.edu/sky-patrol/coor ... 19daf1e0b5
2SPOT
Post by 2SPOT »
Last spectrum of this Sn taken this morning.
And comparison with our spectrum taken November 14th
