I'm trying to achieve the best resolution available with my Alpy600. For doing this, I'm checking the focus of the slit. When I think I have a good focus I perform some images of solar spectrum, together with calibration spectrum, offset, dark and flats, and then I process spectrum and look for resolving power value. The best value I can achieve is a bit more than 500. Very small adjustments inside and outside focus doesn't get a better resolution.
¿Am I following a good tuning procedure? ¿What is your fine tuning method on your Alpy600?
Regards
Miguel
Alpy600 fine tuning
Miguel Rodriguez
Re: Alpy600 fine tuning
Doing exactly the same, having only ~500 resolution too (via Alpy cal.lamp + ISIS v5.4.1 wizard giving this value).
All I can achieve is having better average focus on a wider field (edge areas still blurred - that got focused only when middle is out of focus...).
Using a Landlite 15W "A class" energy saving lamp.
I can turn the core element +-45 degree angle but don't see visually any difference to my old setup (with ~500 res.) - except the up & down borders less blurred.
Interested in the same problem.
- Landlite A class 15W
- landlite.jpeg (18.2 KiB) Viewed 4956 times
Sun and artificial lamps are excellent sources for adjust the focus. A R = 500 is a very correct value for Alpy 600 (23 microns slit width I suppose).
Miguel Rodriguez
Thanks for your comments, Christian. Yes, my slit is 23micron. Good to know I get a correct value.
The first time I tried a fine tuning I used an A star spectrum, and finally got a worse result than before. This time, with Ne lamp spectrum and solar spectrum I achieve R=523.
