Hi Christian,
I have found a difference in the time of observation in the FITS Image header and the FITS profile header - see attached. It maybe I have some settings incorrect but I can't see where.
ISIS Obs time different
- ISIS Times.png (88.71 KiB) Viewed 3283 times
Martin Dubs
Re: ISIS Obs time different
Hi Andrew,
did you put an hour shift by mistake in the ISIS general Tab, - Output? In my spectra I always use UT, this is handled correctly by recording spectra in Audela and analyzing in ISIS. It is also possible that Windows mixes up UT and daylight saving time.
Regards, Martin
Regards, Martin
Thanks Martin that was the problem - regards Andrew
